Desktop/Copy of GPS_TRACE/SRC/init.h File Reference
This graph shows which files directly or indirectly include this file:
Go to the source code of this file.
Functions
void InitLCDText ()
void InitUarts ()
 Initialiseert het Display en plaats de welkomstekst etc.
void initGSM ()
 Initialiseerd de UARTS (RS232 Poorten).
void sendTestSMS ()
 Initialisatie GSM-Module (aanloggen op het netwerk, pincode, etc).
void delay_ms (unsigned short ms)
 [debugger functie] Met deze functie kan indien nodig een SMS worden gestuurd voor test doeleinden
Function Documentation
void delay_ms ( unsigned short  ms  )
Parameters:
none
Returns:
none
Definition at line 5 of file init.c.
void initGSM (  )
Parameters:
none
Returns:
none
Definition at line 40 of file init.c.
References delay_ms(), and uart0_puts().
void InitLCDText (  )
Definition at line 19 of file init.c.
References lcd_clrscr(), LCD_DISP_ON, lcd_gotoxy(), lcd_init(), and lcd_puts().
void InitUarts (  )
Parameters:
none
Returns:
none
Definition at line 32 of file init.c.
References uart0_init(), uart0_send_initial_char(), and uart1_init().
void sendTestSMS (  )
Parameters:
none
Returns:
none
Definition at line 55 of file init.c.
Generated on Fri Aug 17 13:50:55 2007 for GPS TRACE by  doxygen 1.5.3
